$600 Dollar Build Help
I used to be a console player but I have decided to come to the PC (I know, consoles suck now). I know you guys must get a ton of budget builds a day, but I'm looking for a $550 build. I can goto $600 if I need to. I already have a copy of windows 7 in my hands. I would like to play BF3 mid/low settings if possible. Thanks in advance.
im on it, just need some time to put parts together and get the my 275 dollar computer build mind set out of my head, one question do u want just the computer or do u need like windows 7, mouse, keyboard, monitor, etc included in the price
srry didnt see the windows 7 disc part but my question still applies to the other stuff
I have a Mouse and Keyboard, and a 1366x768 moniter, lol. Thanks for helping.
no problem, however i expect gigabuster to show up soon
Yeah, I have seen a lot of his posts. Haha.
yah, i kind of think it like. he is the one who likes to build with intel and im the one who likes to build with amd
i have a question, do u have a favorite color?
for example the case will most likely be black so wat color do u think would look good next to it
OHHHHHH I FORGOT TO POST ON THIS ONE, wait this is another $600 build...
CRAPPERS I FORGOT TO POST ON TWO!!! hold on wheres the other one
your late
oh it looks like the otherone wanted me to build it for him physically for free
yeah  you can play in on medium, high probably at 1080p, at the resolution your monitor can display, I want to say ultra max
I'll get to work on it
well that looks liek a confusing mess of words not sure how meduim settings at 1080p came up
I don't really care about tha case as long as my computer doesn't set on fire. =)
right here it goes:
optical drive: http://www.newegg.com/Product/Product.aspx?Item=N82E16827136247
case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811129066
storage: http://www.newegg.com/Product/Product.aspx?Item=N82E16822148766
mobo: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131795
gpu: http://www.newegg.com/Product/Product.aspx?Item=N82E16814161402
psu: http://www.newegg.com/Product/Product.aspx?Item=N82E16817182066
ram: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231311
cpu: http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727
it should be able to play most of your games at high, in benchmarks the 7770 can play most games on high at 1080p so at 768p it should be able to blow through games, the hdd is only 320gb but i didnt really want to get over $550
the price for the above system is 549.76 on newegg so i was cutting it pretty close however if u want to spend an extra 50 buck i would swap out the hdd with this one instead: http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185
which would increase your storage too 1tb, but makes the price: 578.63
Sweet, I'll go with the 1T probably. Thanks!
i would wait for gigabusters build before deciding finally
I wouldn't go with the 7770, they're bad at battlefield
http://www.anandtech.com/bench/Product/536?vs=660
CPU promocode=EMCNAJF78 ends 9/20
Mobo
Case/RAM
GPU
PSU Promocode=EMCNAJF83 ends 9/20
HDD
a i3 2100 gets minimum 45FPS max 70FPS @1080p, the 3220 is .2Ghz faster and with a enhanced ivy version so more instructions per clock, just up the blck up to 103 for 3.4Ghz if you need a little more umph, the GPU does 80% of the work in battlefield so this should be good
considering the GPU can handle  BF3 at 1920x1200 on ultra with high FXAA at 71FPS I think you'll be good at 1366x768
total with promo codes= $604.93
yah your 660 is better but its also 100 dollars more, however i think both should be able to play games at good settings
now for 100 dollars more on the gpu i could have gotten the 7850, and the results r interesting i wonder y radeon isnt as good at portal 2 and battlefield the results seem interesting
Sweet. I have no idea what to get now. =P I might get a second opinion... Idk...
well something will come out sooner or later
