$600 australian dollar gaming pc build
<p>Im getting a new pc soon which one should i pick. This pc is of course for gaming and do you guys think these builds can run assassin's creed III on medium to high settings no lag?
</p>Build 1
Motherboard
Asrock B85M Pro4 Mboard (LGA1150)
http://www.dcomponline.com.au/productview.asp?proid=8882
CPU
Intel Pentium G3220 3.0Ghz CPU (1150)
http://www.dcomponline.com.au/productview.asp?proid=9158
Graphics Card
 Nvidia Palit GT630 2gb
http://www.dcomponline.com.au/productview.asp?proid=9136
Tower
Cougar Solution 67M3 500W Midi Case
 http://www.dcomponline.com.au/productview.asp?proid=8993
RAM
Crucial DDR3-1600 4GB LongDimm
http://www.dcomponline.com.au/productview.asp?proid=9005
Build 2
Motherboard
Asrock Fatal1ty H87 Performance (LGA1150)
http://www.dcomponline.com.au/productview.asp?proid=8955
CPU
Graphics Card
Palit GF GTX650 2gb
http://www.dcomponline.com.au/productview.asp?proid=8933
RAM
Kingston DDR3-1600 4GB
http://www.dcomponline.com.au/productview.asp?proid=8854
Tower
Build 1 is cheaper but if i get that i can get it sooner and upgrade it later on but im afraid i will loose more money when upgrading so im thinking i should just wait for build 2
Also if you guys have any builds under $600 or just a little over pls send it to me
Pick out parts here
http://www.dcomponline.com.au/index.asp
I live in australia so australian dollar builds would be nice. Also if you guys live in sydney australia and know good computer shops that sell cheap parts please tell me the address.
Thanks guys i appreciate it you took the time help with this. : )
i appreciate any help i will get so thanks in advanced :)
could you please edit your post with paragraphs... I was gonna help but I got a headache trying to mentally separate it :P
im sorry but i have no idea i already tried editing. please tell me how to put paragraphs
umm... press enter after each break...?
it's hard to see where builds begin and end... if your enter key isn't working then create the builds in pcpartpicker.com and post the links...it's irritating to read a big block of text and that's why you're not getting replies
EDIT: actually that's kind of better... lol lemme look through it
ok thanks but ill do the pcpartpicker might be easier
Build 1:
Motherboard: Asrock B85M Pro4 Mboard (LGA1150)http://www.dcomponline.com.au/productview.asp?proid=8882
CPU: Intel Pentium G3220 3.0Ghz (1150)http://www.dcomponline.com.au/productview.asp?proid=9158
Graphics Card: Nvidia Palit GT630 2gbhttp://www.dcomponline.com.au/productview.asp?proid=9136
Tower: Cougar Solution 67M3 500W Midi Case http://www.dcomponline.com.au/productview.asp?proid=8993
RAM: Crucial DDR3-1600 4GB http://www.dcomponline.com.au/productview.asp?proid=9005
Build 2:
Motherboard: Asrock Fatal1ty H87 Performance (LGA1150)http://www.dcomponline.com.au/productview.asp?proid=8955
CPU: Intel Pentium G3220 3.0Ghz http://www.dcomponline.com.au/productview.asp?proid=9158
Graphics Card: Palit GF GTX650 2gb http://www.dcomponline.com.au/productview.asp?proid=8933
RAM: Kingston DDR3-1600 4GB http://www.dcomponline.com.au/productview.asp?proid=8854
Tower: Cougar Solution 67M3 500W Midi Casehttp://www.dcomponline.com.au/productview.asp?proid=8993
Build 1 is cheaper but if i get that i can get it sooner and upgrade it later on but im afraid i will loose more money when upgrading so I'm thinking i should just wait for build 2. Also if you guys have any builds under $600 or just a little over pls send it to me. Pick out parts here: http://www.dcomponline.com.au/index.asp. I live in Australia so Australian dollar builds would be nice. Also if you guys live in Sydney, Australia and know good computer shops that sell cheap parts please tell me the address.Thanks guys i appreciate it you took the time help with this. :)
(I couldn't stand it.... HERE'S THE REPOST) haha
ok thanks now can i get an answer lol
OK so... I don't really like either of these builds... so I'm gonna see what I can do with the Australian pcpartpicker... but build 2 wins so far
im ok with getting the intel pentium for now because those i3 i5 i7 are too expensive on http://www.dcomponline.com.au/index.asp
good lord.... Australian prices are f'in crazy
i know right aus is not a place for pc gamer lol
I'm done.... I was gonna build a $600US PC and it's gonna be like $1000 AUS... go with build 2
do you think the builds i have right now can run ac3 and portal 2?
You have a decent job? What do you make an hour in aus? Not trying to dig just seeing if it scales right...
lol no job in high school saving up at least $600-800 aud i think i have $100 right now
well a GTX 230 isn't much better than intregrated graphics... a GTX 650 will run it ok... I got to $500 on an AMD CPU build before I had a HDD, GPU, and Case... :/
ok is there any other tipe you can give me?
I realize I went way over budget.... but this is what I would suggest for a build...
http://au.pcpartpicker.com/p/2yE2g
I'm not crazy about the PSU but shit good ones were $130
do you have an intel build? also thanks for all the help so far
