Well, I set a budget of £600 and have been setting up my components for over a month, I think I have found myself some pretty decent ones, since it's my first build and I don't know much about how they preform. This build is made for gaming mostly, I am aiming to play on at least medium settings on decent fps.
Well if you have any recommendations or anything please tell me.
That looks pretty solid. If you can find the RAM cheaper at 1600mhz go for that. Ram speed in this system.is not critical so go for the cheapest you can find. Otherwise looks good.
EDIT: Look into a cooler for the CPU as soon as possible. The stock can be noisy and is not recommended for over clocking.
I'm not overclocking and I don't mind about the noise right now. I will probably be getting more fans for it at christmas as I will be upgrading around then.
