Does such a thing exist, and is it safe to use? I have a spare 6-pin not being used by the GPU that cable is connected to, but I can’t find an appropriate adapter cable to use at all. I’d like to avoid using a SATA power splitter if I can, as it would result in some ugly cable management issues.
6 pin gpu is 12v. Usb card probably wants 5v from the sata connector.
