$580 Build good enough?
This is my first post and I need your opinions about my build. I'm just a 14 year old kid living in Philippines and I've researched some about this PC thingy. My budget is only Php 25,000 (Approx. $580 in US).
These are the parts that I've came up: http://pcpartpicker.com/p/1P1dr ($550 total but here in Phil. the total price of parts is Php 24,000)
The purpose of this PC is just for gaming and I want performance more than quality (but of course I'll max the quality if possible). My monitor is just 1366x768 but I'll upgrade it to 1080p in the future.
I've chosen to build an APU system so I can Crossfire it with the HD 7750. I'm planning to overclock the CPU for about 4.4 GHz. The CM Hyper 212 EVO isn't available here so I ended up with the CM Hyper T4.
http://pcpartpicker.com/p/1P1C4
Hi.
The 760K is an A8 or A10 with the integrated graphics disabled. Without the iGPU, the chip is cheaper, and much more overclockable.
This allowed for a great amount of your budget to be placed on the GPU, making the system much faster.
Awesome 1+
You can do MUCH better than an APU setup for your budget. Even the crossfire setup with an APU is not very powerful. The amount you end up spending on the APU setup, which also requires faster more expensive ram, you could spend on a discreet GPU setup which will give you both better CPU and GPU performance.
The only time APU's are really necessary is in small form factor builds where the case is too small to fit any discreet GPU or if your budget is less than $400 or so.
I tweaked your build list and still came in well under budget with a Radeon 7870 ghz edition which should play almost anything on high/ultra at 1080p no problem. This GPU should balance nicely with the 760k which is the A10-6800k APU with the integrated GPU disabled. A very good CPU for that price point and responds well to overclocking.
Here's the revised list: http://pcpartpicker.com/p/1P5jg
I'm gonna +1, although I hate CM power supplies :L Had so many of them fail on my friends it's not even funny. But, at this price point, you're not going to do any better than this.
