hi all, i have 100 euro for a gpu and live in Ireland
i have found a used 560ti @90euro
or a new 7790 @100euro
both are asus DCUii and 1gb
i game at 1080p and basically look for noting below 30fps at medium settings if possible, maybe a bit higher if i can
which would be better for my use?
thanks
http://www.anandtech.com/bench/product/858?vs=776
I'd say you should go for the AMD 7790, as I had some trouble with the 560Ti, such as a ton of different driver errors. I ended up with getting them changed with Msi 660Ti sli. Go for the 7790, og wait for the new R9 series, as it's right outside our doors.
