550w enough for a friend's build?
As you can tell by the title, this is another "is my psu big enough topic" (like there aren't enough of those a day), sorry. I am currently building a rig for a friend for christmas (he's buying the parts, I'm just assembling it for free for him) and, with the help of everyone on the forum I have compiled a list of the components, but I'm unsure if I can use the PSU.
So I've selected a XFX Pro 550w, which I thought would easily be able to handle the components, but the closer XMas comes, the more I'm starting to worry.
The components are these, by the way but with a wireless adapter he scavenged from an old build.
I thought, surely, an FX 6300 and a R9 270X would draw less than 550, even at full load, right? But recently I've been hearing horror stories and am beginning to panic a bit. He has already ordered the PSU, Motherboard, RAM and Case and he wouldn't be able to replace the PSU in time, so I feel like I've ruined his christmas.
Anyway, would this actually draw more than 550w, even at full load?
I've already done the maths and used the eXtreme PSU calculator but, just to be safe, I thought I might post here.
Anyway, thanks for the help.
I am running a fairly similar build and have had no problems with 500 watts.
You choose a good PSU which means that you'll be getting 550W.  should have no problem.
It will be more than fine champ, well done on choosing a good quality psu.
Easily enough. You could use a very power hungry GPU with that unit and still have lots of room for overclocking.
I'd estimate that you have about 150W of headroom, but I wouldn't swap the 550 for the XFX 450, because the 550 will allow you to upgrade.
This web site should help http://www.extreme.outervision.com/psucalculatorlite.jsp
