550$ Build
Hello everyone, I am planning to build a mid range pc for gaming and maybe a little bit of video edditing, It has to be portable because my parents live in seperate houses, and I have a copy of windows so that would not need to be included in the price. Anyways if you can put in your opinion and recommendations that would be great! Here  are the current specs I have:
PCPartPicker part list: http://pcpartpicker.com/p/1gUMh
Price breakdown by merchant: http://pcpartpicker.com/p/1gUMh/by_merchant/
Benchmarks: http://pcpartpicker.com/p/1gUMh/benchmarks/
CPU: Intel Core i3-3220 3.3GHz Dual-Core Processor ($119.99 @ NCIX US)
Motherboard: Asus P8H77-I Mini ITX LGA1155 Motherboard ($102.23 @ Outlet PC)
Memory: A-Data XPG Gaming Series 8GB (2 x 4GB) DDR3-1600 Memory ($49.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($66.61 @ Outlet PC)
Video Card: EVGA GeForce GTX 650 Ti 1GB Video Card ($119.99 @ Newegg)
Case: BitFenix Prodigy (White) Mini ITX Tower Case ($59.99 @ Microcenter)
Power Supply: Corsair Builder 430W 80 PLUS Bronze Certified ATX12V Power Supply ($24.99 @ Newegg)
Total: $543.79
 Thanks,
           BrenDen2425
http://pcpartpicker.com/p/1h4dh
The one you have will work fine but this build is overclockable and is also has a little more power on the gpu.
Please keep these kinds of posts in the respective forums. Build A PC is more than useful. Inbox.exe is for questions usually to the Tek Syndicate team, but in this case there is a respective forum.
I'd move it over but my hardware mod powers don't extend that far.
-moved
and one of the reasons I don't like to use PC part picker is because it mainly shows you the highlighted price AFTER the mail in rebate, that usually takes +8weeks to do, if at all and voids your warranty
you have to pay everything up front
