Will 500W be enough for this editing system with the 4670k overclocked to 4.5 and a possible future GPU?
http://pcpartpicker.com/p/22mnV
Thanks,
Thanks,
It will be way more than enough since I don't see any graphics card in this system.
PS Check compatibility notes
"G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-2400 Memory operating voltage of 1.65V exceeds the Intel Haswell CPU recommended maximum of 1.5V+5% (1.575V). This memory module may run at a reduced clock rate to meet the 1.5V voltage recommendation, or may require running at a voltage greater than the Intel recommended maximum."
Ok Thanks, I am not buying a graphics card right away but I may get one soon.
And I researched the RAM Voltage and found it should not be a problem, especially after overclocking.
Thanks Again,
