$500 Upgradable Build
I have a horrible PC and plan on building one with a $500 budget. I plan on upgrading some of the parts (RAM, GPU) in the future when I have the $. I've come up with this:
CPU: AMD A10-5800K 3.8GHz APU 7660D Integrated - $123.79 @ amazon.com
Motherboard: ASRock FM2A75 Pro4 Mobo - $79.98 @ outletpc.com
Memory: G.SKILL Ripjaws X Series 8GB 1866MHz - $57.99 @ newegg.com
HDD: WD Blue Caviar 500GB 7200RPM SATA 3 - $39.99 @ microcenter.com
PSU: Seasonic G Series 450W ATX 80 PLUS Gold - $79.99 @ newegg.com
Cooling: CORSAIR H50 Liquid Cooling - $59.99 @ newegg.com
Case: NZXT Source 210 Mid-Tower - $32.99 @ superbiiz.com
Total: $474.72
theres no need for an apu in a 500 dollar build
and you dont even have a gpu in a 500 dollar build
also theres no need to upgrade the memory, if anything downgrade it
even though you shouldnt skimp on psus i dont really see the point in such a low wattage psu with a gold certification
and you dont need liquid cooling i dont think.
ive redone your build here
http://pcpartpicker.com/p/Npz1
went a tiny bit over budget but you can surely cut it down
tips for upgradeable: spend more on mobo, get 4GB memory (not a lot of stuff uses more than that these days), I think watercooling is actually going to make it harder to upgrade, too.
http://pcpartpicker.com/p/NpCA
Or bump to a 7770 to fit in budget. Whatever is cool. No real overclocking should be done. If it's that important try a 7770/hyper 212 or T20
i like spenlard's i just changed the grphics card to a 7850 for a few bucks more. just another option i think its slighlty better than the 7790 and come to 505...
http://pcpartpicker.com/p/Nrof
Those AMD Phenom builds boxchevyman and Spenlard suggested are great builds and you will be able to play new games on them as thay stand and have room to upgrade
http://pcpartpicker.com/p/NsYt
Thanks for all the suggestions guys, but when I say $500 build I mean less than $500. I'm actually really tight with budget.
I've changed it up with your guys' help (thanks a ton to everybody). It's most of your (everybody's) parts mixed and matched. I'll salvage my old optical drive, so I don't need to spend the ~$15 extra. How's this?:
http://pcpartpicker.com/p/NvbM
thats really good for 500
but how about getting a 7850 with 2gb vram?
theres alot of them for the same price as the 1gb card.
So this?
http://pcpartpicker.com/p/NDzc
It's actually cheaper and has the same core clock, thanks for the heads up. :P
haha no problem, you look pretty set to me good sir
http://pcpartpicker.com/p/NEwJ
faster memory for the same price
i dont see why not haha
but its your call, even without it your build is pretty flawless if i do say so myself
have fun!
I'm definitely going to use that build- thank you so, so much.
