So I'm planning to build a gaming desktop mainly for steam games. Being a VR enthusiast, I'm also going to buy the "Oculus Rift" so I'm trying to have something decent that can run the two 1920x1080 (3840x2160?) monitors which the "Rift" is mentioned to have.
Heres the build:
- Athena Power CA-GSB01DA
- CPU: Intel Core i5-3330 Ivy Bridge 3.0GHz (3.2GHz Turbo) LGA 1155
- GPU: EVGA 01G-P4-2650-KR GeForce GTX 650
- Motherboard: ASRock H77 Pro4/MVP LGA 1155
- Memory: G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600
- Storage: I have some old SSD's I could probably use
- PSU: what should the estimated wattage be guys?
And then the average wireless adapter. I'm pretty sure this all is compatible with each other. I'm not so sure about bottlenecks though, but to be on the safe side, any thoughts?
