So I have a main gaming rig thats been doing double duty as my VR PC. I have been hunting for a good deal to get me started on a dedicated VR machine as my PC gaming and VR spaces are in differecnt locations of my house. Well I think I found it. I got a used Ryzen 1600 with a AB350 Pro4 board for $90. This plus RAM, case, cheap SSD and I am just under $300. I already have a extra monitor, wifi card, keyboard, mouse and power supply.
Question is do I go for a used RX 580, Fury or Vega 56 for it? I am using a 1st gen HTC Vive now. We play a mix of VR games in the house but none seem like they would be too demanding. With VR is the 4GB of VRAM on a Fury going to limit the PC? Is a used Vega 56 for abount $225 worth it in a post RX 5700 2019? Sould I get the 580 and just expect to upgrade when I get a new HMD?
280$ is brand new with warranty and everything. So 225 is maybe not that great of a price. On the other hand RX 5700 is faster, uses less power, have more Vram, that is going to be more or less important. You kinda run 2 separate monitors - one for each eye, and on top of that, you have a separate monitor monitor, so more Vram - the better. Not really for rendering, but for buffering frames.
Basically if you can squeeze 5700 in the budget - go for it. Otherwise go for the best GPU you can afford. You kinda need the highest framerates possible, or be prepare to kinda vomit a lot…
PS: hello new guy or girl or inbetween. Welcome to the forum. If you see a fluffy puppy - don’t worry, he’s a good puppy, he doesn’t bite. The lounge is down the hallway to the left.
R9 Fury/Fury X is a 4GB card, wich will probably come back to bite you. [Note: I am in the process of replacing my Fury with a 5700XT because I am out of VRAM at times.
580 8GBcould work maybe.
Vega 56/64 should work, both can be found for cheap now.
If you can squeeze in a 5700 or maybe find a used 1080/1080ti for cheap, will give you the best experience.
