Building a moderate build based on the Sandy Bridge i5
http://pcpartpicker.com/p/u3ac
Reusing Hdd, Optical Drive, Windows 7
I kind of cheap out on some parts lke the mobo. Need some Feedback on the build. Thanks.
I think youre cheaping out on the MOBO, but the rest looks good.
Get a different motherboard that doesn't even support the speed of the memory you have picked out!
Also get a power supply that is 80 plus efficent and has a single 12v rail.
http://pcpartpicker.com/p/u4iY here is one. With a CPU Cooler included. You willing to go AMD? Reason I'm asking is so I can add more options
That will work.
Caught ya off guard i take it? LOL jk
Sure.
