hey guys,
this is my first build which i probably gonna do in the summer.
im on a pretty strict budget, so i can't really go over
its actually a 400 dollar build but i need a monitor and a wifi adapter
heres what i have so far:
http://ca.pcpartpicker.com/p/SQSi
any suggestions?
hey dude, that's a pretty good build. :D But 6670s will force you to play games on medium, yet a nice budget card. Could you go over $50 in your budget? If so, here's a nice $550 Gaming system (Not Logan's, though)
http://pcpartpicker.com/user/BGGhast/saved/1vQe
Forgot to post teh link. Check my post. And you live in Canada? (me facepalm)
Okay, I'll try another build
and for a little cheaper, i managed to do this
http://ca.pcpartpicker.com/p/SRG0
which ones better, the amd build or the intel?
