Does anybody have a pc build for 500 dollars thats good enough to play dayz or bf4 on normal+ settings?
This system should be able to run those games on medium at the least. Hope this helps man!
http://pcpartpicker.com/p/2gnbK
Changed it ever so slightly because the 7850 isn't much more expensive than the 7790.
This will handle BF4 on high settings - and you might even get playable frames on ultra.
http://pcpartpicker.com/p/2gAYP
$514 before mail in rebates. And sub 500 after MIR
What he said XD forgot the price drops on the cards.
You took the hard work out of the design. Thanks! ;D
XD hahah your more then welcome !
Is it that big of a deal that it doesnt have usb 3.0 ports?
and should i get a fan for the cpu or does the one that comes with it work good enough?
if your not going to overclock the stock cooler will be just fine
The stock fan that comes with the Athlon is good enough. However, you will want to replace it at the first available opportunity.
Though, the case doesn't have USB 3.0 ports on the front, you will be able to access the USB 3.0 ports at the back, located on the motherboard.
You can find some cheap cases with USB 3.0 on the front from around the same price. So if you want to find a better case and include that, it shouldn't cost too much more. Then you'll probably want to buy a cheap $25 heatsink to replace the stock CPU heatsink. There's no rush to do so, but AMD's stock coolers are a little louder and hotter than they need to be...
so should i go with this http://pcpartpicker.com/p/2gBqw
or this http://pcpartpicker.com/p/2gBjK
There's no price on the 7870 GPU in the first link. I fear that would go extremely over budget.
The 750k and something like a 7850 or 7870 or Nvidia equivalent (generally AMD are better at this price point) is all you need for high/ultra gaming experience in 90% of games.
This is a stupid question but i have to buy each part individually or is there a buy all button
Depends if you want to buy them all from the same vendor or not. I would try and get the cheapest price obtainable - which often means buying from separate vendors.
If you buy from the same place, you might save on shipping, and you can conveniently purchase everything together in your "basket".
PCpartpicker is not a substitute for that, though. You have to go to the individual websites. PCpartpicker should factor in the cost of shipping on most websites.
