500 Dollar Micro ATX Gaming Build
Budget. How much are you willing to spend?
500-700 USD
Where do you live (what country, don't post specific details), and what currency do you use?
United States
Is there a retailer you prefer?
Newegg
Do you need or already have peripherals? (this can add to costs)
no
What will you be using your Glorious computer for?
Gaming
Do you overclock or want to get into overclocking?
no
Do you plan on going for custom water-cooling now, or in the future?
no
Operating System. Do you need a new one?
no
Microcenter has 30 off on intel bundles and 40 off AMD bundles, CPU+MB and some of the open box GPU deals are great.
A bit over the budget...
http://pcpartpicker.com/list/6sGzKZ
Total: $745.20
EDIT: we are expecting in less than a month way more powerful GPUs for around 200$. AMD releases their new GPU line... Until then you can use your integrated gpu in the i5...
The monitor is Freesync 47-75Hz through DisplayPort. It will allow you smooth gameplay even in lower than 60fps...
So you don't need a monitor? I would say that a locked i5 and a 470 or 480 would be the way to go with an ssd and a nice, small case. Could even go miniITX and sff.
wait for the 480. you are throwing money away with 380. be patient.
