I need a 500$ Canadian dollar pc build you could try using ca.pcpartpicker.com
I dont need a os, mouse or keyboard just the tower.
Story: i have a sff pc but i decided to build a new one rather than upgrading the old pc so could you help me with the build plz :)
What games are you going to play?
Other option would be an APU build that compromises overall performance for better other components
PCPartPicker part list: http://ca.pcpartpicker.com/p/BVx3rH
Price breakdown by merchant: http://ca.pcpartpicker.com/p/BVx3rH/by_merchant/
CPU: AMD Athlon X4 860K 3.7GHz Quad-Core Processor ($96.98 @ NCIX)
Motherboard: Gigabyte GA-F2A78M-D3H Micro ATX FM2+ Motherboard ($84.75 @ Vuugo)
Memory: Team Elite Plus 8GB (1 x 8GB) DDR3-1600 Memory ($45.98 @ Newegg Canada)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($58.29 @ Vuugo)
Video Card: XFX Radeon R7 360 2GB Core Edition Video Card ($151.98 @ NCIX)
Case: BitFenix Merc Alpha (Black) ATX Mid Tower Case ($29.88 @ Canada Computers)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply ($51.99 @ DirectCanada)
Total: $519.85
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2016-01-04 23:29 EST-0500
Will the cpu work out of the box with the motherboard
If yes then i start ordering the parts
Motherboards usually get updated when new CPUs come out
http://www.tomshardware.com/answers/id-2605837/860k-motherboard-support.html
The performance is close between the 750ti and 360, but going with the AMD card is going to give you potentially better DX12/Vulkan support because current gen Nvidia cards have issues with asynchronous compute
also it's like 20 bucks cheaper
Ya but i want cards with good rating not that the card you put is bad its just i am more relaxed if i know the card i am getting is gonna be good( first time building pc)
Also will it work with the build
Will the 750ti work
It's 4/5 on both newegg and best buy from a good number of reviews
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150736
the 750ti will work fine, but you're going to end up with less support in the future if game devs start to utilize a-sync, which they probably will because it'll give GPUs more performance
Of course if you wanted to save up another $50 or so you could step up to the 370 and that's going to beat both of these cards by a decent amount
https://ca.pcpartpicker.com/part/powercolor-video-card-axr73702gbd5ppdhe
If anything just ditch the case and shoot for the 370
Course again the other option is an APU rig which will let you game fine for a while while you save up for a higher end GPU
If i get the 750ti i will be able to upgrade to a 370 later right? or a a sync gpu and the build has no problems right will it work right away after I assemble it
You could do that, but then you have a 750ti just sitting around,
Just spend the money now if you were going to upgrade the GPU, if not the 360 is probably the way to go, although with canada's pricing the 950 is a better option than the 370 as a step up
There's also the R7 265 at $150 CAD, but it's backordered on this site, if you can find it elsewhere for that much it would be a pretty solid card
Money isnt really a problem its just i want a gpu that will last so what do you think is the way to go
Here the link if you want to edit it and show me what you think the way to go for the gpu
http://ca.pcpartpicker.com/p/JsqtMp
Well if money isn't a problem then why is your budget so low, you should be getting an i5 + 380 and that'll last a good long while
anyways the 950 is going to be a lot better than the 750ti for $20 more
PCPartPicker part list: http://ca.pcpartpicker.com/p/FVHCNG
Price breakdown by merchant: http://ca.pcpartpicker.com/p/FVHCNG/by_merchant/
Motherboard: Gigabyte GA-F2A78M-D3H Micro ATX FM2+ Motherboard ($79.99 @ Newegg Canada)
Memory: Team Elite Plus 8GB (1 x 8GB) DDR3-1600 Memory ($39.99 @ Newegg Canada)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($63.95 @ Vuugo)
Video Card: Gigabyte GeForce GTX 950 2GB OC Edition Video Card ($198.29 @ Vuugo)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply ($50.22 @ DirectCanada)
Total: $559.30
Generated by PCPartPicker 2016-01-05 20:43 EST-0500
Thx for the help with the build i will have to chose between the 950 or 750 ti I Know 20$ isnt a big difference and probably i will pick the 950 but thx for helping me out and this build will work with all the gpus we talked about right ? Gtx 750ti r7 360 gtx 950 etc
Any GPU is going to work in any system, assuming the power supply is good enough
Pretty sure this 500 watt powersupply will handle the 750ti or 950 unless i am incorrect?
I decided to go with the 750ti but thx for the help
You should really go with the 360 instead, more so you should really go with the 950 if you're going to buy that $170 750ti
the power supply should be fine it has decent reviews but it's a pretty basic one
