$500 Build
I'm helping my friend build a PC. His budget is $500.
http://pcpartpicker.com/p/2pQUV
I'm giving a case and the plan is to install windows from a USB, which is why there is no optical drive. Does the build seem good enough to play games for a while until he can upgrade?
get some faster ram, the APU drastically benefits from fast ram in graphics performance (1866 at least)
http://pcpartpicker.com/p/2pSp7
don't know about the mobo. you should go more indebt. but the fx 6300 is a beast. the 7850 isn't that great with the 1gig but your in a bad time for gpu shopping know. find a 7870 2gig or a r9 270 non x. i have the msi r9 270 @ 1100mhz. runs tombraider max out on 30-60fps with a i5 750. fx 6300 beats that. and a case?
and this is maybe an option. do you have and older pc. ifso, you have allready ram, case, hdd, and if the cpu is good you can throw a gpu in it. i did that with my old dell pc. 400$ for a gaming rig isn't a whole lot. try pirate bay for a copy of windows and buy a better gpu. ahtlon 750/760 is also a option but i prefer the fx 6300. can't beat that.
Deleted my post since yours was basically what I said plus you had a link to pcbuilder. The only thing I don't like is the motherboard you listed does not support USB 3.0 and SATA III so if you needed any of this to be less needy of a upgrade I suggest a 970 or 990 motherboard although that would be about an extra 50 bucks.
This is a lower price than the build above.
http://pcpartpicker.com/p/2pTm3
While the build above is better than mine, this is more affordable for you. And it will certainly beat the APU in performance.
