Hello, I created this build and I was just wondering what you guys think about it. The build can be found here: http://pcpartpicker.com/p/nd81. I do want to note that I did already purchase this build, when I purchased it the build costed just shy of $500(Since my budget was $500). The point of me posting here is so I could learn from any mistakes I may have made while creating this build.
*Note: This computer will be used for gaming mostly.
Looks good, but I'm wondering if that PSU will provide enough wattage. I don't know. I just heard that you should use a 450W PSU with a 7770. If 430 is not enough, then it might burn out. If that happens let me know, because I have the same power supply and I'm thinking of getting the 7770 too. Don't want my PSU burning out either!
I'm sorry I used this optical drive: http://pcpartpicker.com/part/lite-on-optical-drive-ihas124-04, my mistake. I would never buy an optical drive for $30.
I'll make sure to tell you if I ever have any issues. It may be a while however because I don't get the computer until Christmas. I had the same thing on my mind and I asked some people. They said it should be fine so we will see.
