Teh build for $500.
It includes an SSD, which will make the computer loading crazy fast.
http://pcpartpicker.com/user/BGGhast/saved/1vVk
Teh build for $500.
the best eh?
*cracks knuckles*
them's fight'n words
what kind of build is it for
a facebook machine?
Nice, but I like this a little bit more
http://pcpartpicker.com/p/SVrX
It has less overall storage, but a larger ssd
twice as much ram
I believe it is a better cpu
and only $6 over..
and you can add a big storage drive later when the person saves up a little more
Yeah, I was overexaggerating (Is that how to spell that?)
But is dat a good gaming rig for $500??
$500 gaming rig that will blow your perception of economy coming up
within 4% of budget range
http://www.anandtech.com/bench/Product/536?vs=680
Children please... http://pcpartpicker.com/p/T5Y8
Puh-lease, step away from the king. http://pcpartpicker.com/p/T8P8
+1 for Wadjoosay´s build
The Mudrii build is also not bad, but the the Phenom 965 125 W cpu, on that Msi 970A-GD46 is a bit tricky, ofc it work fine, but you not gonne get room for oc, those boards are well known about theire Weak overheating VRM´s on powert hungry cpu´s, if you put in a 95W tdp cpu then you more safe on that.
the Asus M5A97 R2.0 is a much better board. with 4+2 power phase, most boards in that price range come with only 4+1, the Asus is also designed with that power phase for cpu´s with max tdp upto 140 W..Maybe its a bit inrrelevent information, but i tought i just name it.
Grtz Angel ☺
500 dollar isn't much for a gaming build.
Why would you want and ssd for a GAMING build? It wont increase performance in games, only the startup times. It costs a fortune taking away from the already small budget, so no. Besides you want LOTS of reasonably fast storage for all your games!
My idea:
http://pcpartpicker.com/p/Tce8
waddjoosay wins hands down packs the best graphics with the least price
