$50 mouse
Hey there TekSyndicate community,
Like what the title says any mouse out there that is around $50 here in the U.S. I know the good ones are like more than $50. But I want to know if that price range can give a good mouse nonetheless.
What I'm looking for with that mouse:
- side buttons are nice but nothing crazy like that logitech g600 (will still take that logitech g600 mouse if no other mouse can fit my preferences)
- programmable buttons
- wired
- can handle some light gaming (what I mean by light gaming - 4 to 6 hrs of strategy games like Civilization, & DotA 2 and maybe couple of hours of Team Fortress 2)
- preferrably right hand focused design
Note: I maybe able to squeeze in another $10 but that's still a stretch.
http://www.amazon.com/Logitech-G500-Programmable-Gaming-Mouse/dp/B002J9GDXI/ref=sr_1_1?ie=UTF8&qid=1381109931&sr=8-1&keywords=g500
cant go wrong with Logitech I have used this mouse and I think its a very solid option for $50
Any Zowie mouse(except MICO) ~ 60$
Logitech G400 ~ 50$-60$
Razer Deathadder 2013 ~ 60$
Most quality gaming mice I know go for 60$. All these mice I listed here have basically the same performance, as long as you make sure you get the version of the G400 without prediction(Google it)
If you don't mind waiting, whenever this mouse comes out, it'll probably be a VERY GOOD mouse(the best on market if it doesn't have any prediction or acceleration, etc problems.), but only time will tell. Going to go for ~45$ http://www.esreality.com/post/2487925/new-gaming-mouse-development-pt-2/
Steelseries Sensei Raw can be had for $55 - $60.
Thank you guys for the suggestions. And right now I'm kind of leaning towards the G500 because the side buttons are really pronounce and that DeathAdder.
I won't be buying anything yet. I'll leave this post up for a couple of days just in cause someone comes along with another suggestion.
http://www.amazon.com/Perixx-MX-2000B-Programmable-Gaming-Laser/dp/B0083H4NG4/ref=sr_1_3?ie=UTF8&qid=1381218539&sr=8-3&keywords=perixx
How large are your hands?  Small, medium, large?  And what grip style do you use?  Palm, claw, finger tip?
All the mice mentioned above are great options.  The G600 is a solid option as well.  I personally use this mouse. Like you, I was a bit skeptical at first.  I didn't think I would need/want all those buttons, but I typically use 6 of those side buttons on a daily basis.  They are really handy.  I particularly like this mouse because of its size.  All other mice I have tried made my hands cramp; whereas, the G600 fits my hand really well.
Here's a great alternative to the Deathadder...
http://goo.gl/PyK6Ow
I'm not trying to fanboy over any mice or company, but I really wouldn't recommend using any mice that I didn't name. I personally hate all "gaming" companies (ex. Razer, Steelseries, etc) because they usually have... "unloyal" products I guess you could say. They don't fulfill their promises. (and I even recommended the deathadder, because it's one of the few great mice out there.)
Also other good mice that I didn't name were: Microsoft Wheel Mouse Optical 1.1a, Microsoft Intelliemouse Explorer 3.0, or Microsoft Intellimouse Optical 1.1a.
The problem with the G500 is it has little sensor problems: acceleration (negative acceleration I think.)
Basically, if you really play TF2, and mayble plan onto playing dota competitively, this type of thing will really matter(Mostly in FPS games). In games like dota or civilization, you don't need to be as precise though. So pretty much if you don't really plan on playing on a competitive level or many fps games, you can basically disregard this.
Just a quick thing, before anyone says something like "But <name> is really good in <game> and he uses <SteelSeries, Razer everything>"... Sponsors my friend, Sponsors.
Other note: You don't have to take my advice. Buy whatever mouse you want. I'm just trying to help out.
Well, everytime I would use lab gloves I would go for the large ones so I guess I would consider my hands "large". I just have really long fingers. And as to the grip style, since I have long fingers I would usually hold the mouse with the my fingers stretched out. Imagine shooting force lightning out.
And as for that Zowie mouse, I'm skeptical about how it's shape. It would force me to "claw" up my hand.
From what I've read about the G500's negative acceleration, it's all the drivers fault. Did Logitech or any open source driver fixed that?
And don't worry about expressing your opinions on mice. I don't know that much about them that's why I'm trying to be as open as I can. So that in the end I get a decent experience out of it. My current mouse is actually an old kensington pro-fit mouse.
Dude, this mouse's form is ideal. Thanks!
But if someone out there in the community can suggest an even better one then great. I really appreciate the suggestions, guys!
Does anyone have an opinion on the Ballista MK-I for Shogun Bros ? Looks like it would fit you requirements.
http://www.amazon.com/Shogun-Bros-Ballista-8200dpi-Commander/dp/B008UR04T2/ref=sr_1_1?ie=UTF8&qid=1381248554&sr=8-1&keywords=shogun+bros+ballista+mk-1
Seems to be a lot of mouse for a reasonable price ?
Well, G500 has a laser sensor and you can't possible not have any kind of acceleration with a laser sensor.
Although most of the people wouldn't actually notice the difference in tracking other than obvious things like laser sensor being sensitive to dust in the sensor, having higher lift-off distance and not working properly with some cloth mousepads.
And well, G500 is also very heavy even without weights.
Sorry for the lack of info on it. I have only just got it a few days ago so do not want to endorse it too much but it I am enjoying it upto now.
Dissentient pretty much says it. Stray away from laser mice.
A sensei raw for 30 bucks http://www.amazon.com/SteelSeries-Diablo-III-Gaming-Mouse/dp/B005L38QK2/ref=sr_1_10?ie=UTF8&qid=1381281279&sr=8-10&keywords=steelseries+mouse
How about this mouse?
CM Storm Xornet, really good mouse imho and it's only around 25$. http://www.amazon.com/CM-Storm-Xornet-Optical-Switches/dp/B005TEPB74/ref=sr_1_1?ie=UTF8&qid=1381290330&sr=8-1&keywords=cm+storm+xornet
