$50 headphones
I want to buy headphones but I don't want to spend a lot of money so I am thinking in something like this
http://www.amazon.com/Creative-Blaster-Tactic-Gaming-Headset/dp/B00EO6X9YA
but I don't know if that others worth the extra $10
http://www.amazon.com/gp/product/B008Y1KK6Q/ref=pd_lpo_sbs_dp_ss_2?pf_rd_p=1535523722&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B0041OQKIC&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=1NAY0YCHADS6BCTDHJWG
http://www.amazon.com/dp/B005B1BE08/?tag=pcpapi-20
or maybe there is something better for the money but I just don´t know, I have a microphone, so it don´t have to be a headset
I would be listening some metal and playing LOL
Really don´t know what to look for in a good pair of headphones XD
The Best Headphones Under $50: Superlux HD681 & HD668B Headphones
https://teksyndicate.com/videos/best-headphones-under-50-superlux-hd681-hd668b-headphones
http://www.amazon.com/Takstar-Monitor-Headphone-Gaming-Computer/dp/B009PIQUB6
OEM of the Qpad Qh-85.
Ridiculous good for the price.
I think the HD668B is the way to go, thanks a lot =D
These were recommended in another forum.
http://www.amazon.com/California-Headphone-Co-CHC-SILVERADO-Headphones/dp/B009F4BV8C/
Look for a nice clean high quality 2nd hand pair imho.
Before you do choose a pair, try and find a store that stocks them so you can at least try them on. Nothing is worse than having a set of cans that 1. dont fit your shape head nicely, 2. dont fit your ears properly, 3. are flimsy as hell - creaking with slight twisting etc.
+1 on the 668b's. I have a pair, and they are excellent after the approximately 30 hour burn in period. I'm also working on a few mods for them, I may make a forum post about the process. I have replaced the acoustic dampener in them with something similar to clay (it's actually the blue tacky stuff for hanging posters) and it has improved the sound a ton. I suggest checking out some threads on the rock audio forums, they have a full list of mods you can do. Regardless, right out of the box these compete with 100+ dollar cans. Get them.
+1 on the HD668Bs as well, I have a pair and they are fantastic
