5 1/4 inch IO
Is there such a thing as a 5 1/4in bay io to replace a front io? I'm just wondering... I know there are fan controllers and usb stuff but like power/ reset switch some usbs and a couple of fan controller nobs is there such a thing?
yes.
This would be easy to make if you have a blank cover and a drill.
Here you go: http://www.lian-li.com/en/dt_portfolio/bz-u08/ I managed to find just this actually, but maybe there's more around.
thanks time to get rid of the side io on my prodigy :P
That's not an universal 5.25" bay accessory. It only fits the Lian Li D8000.
there's always something for those who look
http://www.newegg.com/Product/Product.aspx?Item=9SIA24G3434898&cm_re=3.5_to_5.25_bay_adapter-_-17-994-178-_-Product
Or there's this
http://www.frozencpu.com/products/23167/bus-375/Scythe_Kama_Panel_31_525_Multi_Function_Panel_-_Black_SCKMPN-3100_.html?tl=g34c139s296&id=r3I5vmPn
Only the kitchen sink is missing.
But anyway, what you're looking, they're out there. Go find them :P
