4k Bluray SGX!
Hi,
I would like to say from the offset this is not a discussion on the usefulness, viability or alternates to 4K blurays as I am sure I will get many opinions wanted or not on this :rofl::rofl::rofl:
Basically I have a 4k Dell XPS 13 9370, and I have some 4K blurays that I obviously want to watch on said laptop…
I have the Cyberlink Power DVD 18 which can run 4K however can my laptop? Does it need any graphics power to do this as it is only built in Intel graophics?
I have run the CyberLink 4k bluray tool and it is all goof apart from the missing bluray drive (I will buy a external USB C one) and it says SGX wasnt started? (see screenshot)
I have gone into the bios and it is activated and has 128mb allocated and done a few restarts with no different answer, any ideas? is it likely to be fine and maybe a faulty reading for some reason? (Not really knowing what SGX is)
Very many thanks for any help
Intel SGX is some sort of DRM. Maybe try to disable it and then re-enable. Or try to update your BIOS using DELL command/update. Apart from that I don’t know bud.
I love how you run Windows 10 with dev version of Firefox but then you have MS Office 2007. lol
Thanks I will try that :slight_smile:
Haha that’s how I roll…
Take this for what it’s worth, but 4K UHD playback directly from discs is a complete mess up on the PC platform. You have to have the exact DRM and hardware/cpu support.
Instead, get a LibreDrive / MakeMKV / AnyDVD HD and just rip the disks from a standard blueray drive, and enjoy forever without all the trouble.
