Since it lists support for DSC, will the DP 1.4 / USB-C KVM handle a single 4K / 240Hz signal (coming from a 4090 which also only has DP 1.4). Thanks!
with good cables, it should be okay. we’ve tested it and it works @Level1_Amber just don’t try to use two 10 foot cables. even two six foot calves might be pushing it, but there’s lots of success stories here.
I just wanted to confirm before purchasing the triple monitor kvm myself. A single 4k 240hz center display with DSC flanked by 2x 60hz 4k displays should also work in theory assuming the same guidelines (short, quality cables)?
yep it’s 1:1 input to output
I’m in the same boat.
I have:
- 4K@240hz OLED * 1
- 4K@60hz IPS * 2
hooked up to windows PC, and M4 Mac Mini.
I want to make sure the windows PC can still output 4K240hz on the main (center) monitor for games, while on m4 mac mini 4K@120hz is fine.
is it possible on the Combo USB-C Power Delivery & DisplayPort 1.4 KVM - Triple Monitor ?
It’s a tentative yes, but you need short as possible, high quality cables. Switching from a monitor set to 240Hz to a different PC that only supports up to 120Hz might cause some trouble, might not though.
RIP to all my current 10ft DP cables ![]()
Do you need the short cables from PC - KVM or KVM - Monitor, or both?
I’m going to use TB3/4 cable from mac mini - KVM, so that’s going to be short.
xD short as possible for both
