So I was just wondering what would be better for this case. I need a computer that will be used for extensive CAD work, CFD analysis and other engineering/science related schiznic (ie. a lot of Solidworks.
How much performance difference will there be between a 4930k and an equivalently priced Xeon? Might be used for some moderate gaming, but I don't want that to be the determining factor here; if there's a 5% performance preference towards the Xeon, then that's what I'd opt for.
And as a side question, how much difference between a WS graphics card and a gaming graphics card for this use case? (with around $1000-$1500 for the GPU setup)
Well, you will get a bit more cache and ECC ram support. That might help with a few of those programs. The i7 is extremely fast and I'd wager it will be quite snappy and the gaming performance will be a bit better. I think Wendell could probably give a better answer... but I wouldn't stress over it. The i7 is really fast... as is the Xeon.
Xeons are not ment to be used for performance use. Unless you go for a very high end xeon, you will see a bottleneck. Dual xeon aproach just isnt realy viable as games still are not optimised for the number of cores. the 4930k will in your case be better in performance. Xeons are really only for stability. If you need a really stabel system with redused number of incorrect calculations, Xeon is the best way to go. However price to performance is poor.
Quadro's are esentialy old Geforce cards that are optimised for OpenCL and other professional enviroments. If this a pure work station and no DirectX is used, Then a quadro is your best bet. They can game but that is not what their designed for. While a Quadro K6000 will perform on par with a GTX 560 in Direct X, It will completly destroy a GTX 780 in professional enviroments. Even a Quadro 400 will do better and that is a $200 card
I am a 3D Modeler and Animator and I had to make a choice. Seeing as im such a gamer and my work is tailored towards Game design. I bought a GTX 780 just today.
If you arnt gaming at all, Get a quadro. If you do game on your system. Then well. Decide do you want sub par professional enviroment or sub par gaming? If you game, The new AMD Cards will out perform the Nvidia cards in CAD and in some cases games aswell.
