Hello, I just built a computer for gaming, and eventually using adobe, but i got adobe through my school for 100 dollars and found that my i5 just cant run the programs very well, my specs are:
Intel core i5 4570
Asus z87-k
8gb corsair xms3
gtx 650 ti boost
cx600 psu
Should be nothing wrong with the capability of that processor.
You should spend money on the GPU.
it runs games fine, but I'm looking for better performance in rendering, and streaming
The i7 will have hyperthreading, which many adobe products take advantage of. Add that to the better out of the box performance across the board and the ability to overclock, and it should be a pretty decent jump for what you are wanting to do. Whether or not it's enough of a performance boost to justify the extra money, that's up to you.
It'll be less noticeable in say Photoshop (where it could improve certain things by a few seconds) for example than it would be in Premier (where it could improve certain things by a few minutes). So it depends on what Adobe programs you use most.
