Hey everyone. I've been following Tek Syndicate for awhile now and I've finally decided to join the forum. Moving onto the real topic!
Today I put together my first PC in quite a few years so the process was a little slower than usual, but I managed to make it through. It booted on the first try to my surprise (Success!) and immediately went into MSI's UEFI BIOS in which I started poking around. My idle CPU temp was sitting at 37 degrees, and the motherboard was sitting at ~10 degrees less. I'm wondering if this is okay for my setup, or if I should try removing the heat sink, cleaning it and reapplying the thermal compound? I've left it running for ~45 min with no change to temp except a mild jump to 40 degrees when sifting through the BIOS options. I feel like this might be too high, but I'm really not sure after reading so many "Haswell runs hot" stories. I've made sure the heat sink is seated properly, but that's about all I've done.
Here's my new setup:
Motherboard: MSI Z87-G45
CPU: I7 4770K @ Stock
Heat sink: Cooler Master Hyper Evo 212
RAM: 8GB (2x4) of G.skill Sniper @ 1600MHz
I used the pea-method and the thermal compound that came with my Hyper Evo 212.
Also, I haven't received my GPU or OS yet. They're currently shipping from Newegg, so any kind of stress testing is out of reach as of now, unless there's some way to stress test within the BIOS?
Any help is most appreciated. Thanks!
I apologize in advance if this is in the wrong place. I'm pretty forum-illiterate, as you can see.
