475.- swiss Build
Hey guys!
before i give you the link to PCPartePicker i have to explane the situation: i have to wate t 'll june to build my dream PC bu the sh*ty PC i am on now is an 6 years old xps 430 from dell and it s starting to have blue screens for not a lot (youtube vid watching). So here is the part list!
http://pcpartpicker.com/user/Stephenn4/saved/3Dsw
i already have a screen (even if it s bad too (it s stil square)) a keyboard ( Roccat Valo) a mouse  (rat7) and a headset (Gamecom commander!)
I based my build on the 350$ pc build on the tec syndicate chanell but i had to take what was avaleble in swisserland!
tell me what you think! thanks you!
That build should do the trick. Consider getting 1600mhz RAM instead. You will have to overclock to be able to use the 2400mhz ones.
Can you tell us what size your case is? You might be able to get better parts in a micro atx system than your mini itx set up you have listed.
i think i am going to buy the fractal design core 1000 beacaus i want to sell this pc wen i am not going to have my new one!
http://pcpartpicker.com/parts/partlist/ overbudget by $67 -- > $542.51
I've included the Case and a larger PSU for when you upgrade to a graphics card later. I've also included the A10-7850K in the build which puts the price up, but you could go for a cheaper A8-7600 which will be better than the APU you had chosen but for around the same price. Unfortunately it's not listed in pcpartpciker just yet.
I also swapped the Hyper 212 evo for the noctua cooler because the Evo won't fit inside that case. The noctua cooler is very very good at that price!
If you swap down to the A8-7600 (assuming you can get it where you are) and the smaller PSU (limit upgrade later or have to replace later but meh it's only $20 lost if you do) this should bring you back within budget and be a vastly better machine than your original build there. Does not have wifi built in but you can get a pciex1 slot card for about 10-15ish dollars if that's a must.
