so I recently purchased a noctua NH-D14 and wanted to do some crazy overclocking (I'm at 4.5ghz atm)
but after I installed it, I noticed core #3 is running about 2-5c hotter than the rest.
now using my previous overclock, which was 4.5ghz @1.255v (its that high since I would get random crashes in CSGO) the noctua idles around 32, under Aida64 hits a max of about 65-70c, intel burn test, hits 80c with a few spikes up to 85. but prime95 starts at 60c, then slowly creeps up to 95c and my computer crashes.
How do I improve stability? should I be tweaking the cache ratio and voltage? did I apply thermal past incorrectly?
Don't use prime95 for haswell based CPUs, they don't play well together. 1.255v isn't high, 1.3v is safe as long as you keep the thing cool.
You should leave cache alone for the most part, not much to gain there, but bumping your system voltage, CPU input voltage and cache voltage slightly can help with stability.
If you are already stable-ish at 4.5GHz these should get you to 4.7GHz. You can also sometimes control temps by setting your Load Duration Limit to 2-4 seconds. Doesn't work with every scenario, doesn't hurt.
ok I looked at that, I'll do that methode next time I reseat the heatsink (if at all) the temp difference seems to be droping to about 1-2c so I guess the as5 is settling i.
@Fouquin yea taht worked, I'm more or less stable atm, just doing stress tests atm, wanna do intel burn test but scared that might over heat it.
LLC is set to level 2 (Asus z97-a) and PWM isn't available to my knowledge.
thanks for teh input, only issue is now I want to do 4.8ghz..... best not to.
I think a pea will be fine however, since thats what I did on my previous heatsink it was pretty evenly spread over it, except for the part of the heasink that wasn't even on the CPU since Enermax makes some really loose fitting heatsinks....
ok 4.7 isn't stable at all, I think my chip has a voltage wall, I couldn't get it stable at 1.35v and I don't want to go any higher, I'm going to settle for 4.6.
