is it 25c at cooler going 100%?
I use a Noctua D14 on a 4790k and idle at 21-25c. I habe undervolted 4.4 @ 1.14volts and I peak at 52c when gaming.
I have corsair h100i with noctua nf-f12's in pull, with the low-noise adapters on. No its idling at that temp because thats how cold my room is too. On full load with aida64 just now I ran the test for 15 minutes and it peaked at 69 degrees Celsius. My cooler is similar to yours in terms of noise, static pressure, and heat dissipation. You should be having similar results as me. The nepton is a good cooler. The fact that you're not, and running at stock, does scare me a bit.
http://www.hitechlegion.com/reviews/cooling/liquid/41902-cooler-master-nepton-240m-liquid-cpu-cooler-review?showall=&start=2 comparison of netpron 240m and h100i
my numbers are similar to that review, my idle is 31c
at stock cpu speed i get 31c idle and 60c aida 64 stress test with checkmarks next to cpu and fpu
How effective is the static pressure in your case?
Here watch this
https://www.youtube.com/watch?v=g8EN3K-eaVA
just finished running aid 64 and my temp was 53c, do you think that's good temp for stock? because i want to overclock this cpu but first i want to make sure that all components are working the way they should and don't overheat.
1 intake, 3 exhaust, i also ran ran aida 64 with case panels on and off and the difference was 2-3c
I PM'ed you. Check your email.
do you have skype?
btw you can just rejoin the chat by clicking on the link again
That temp is fine.
We fixed the issue guys, its all good now.
and was the solution?
Would be handy for other people with similar issues.
the pump wasn't tighten down all the way
allrighty thanks ☺
Knew it ;)
