£450 build
http://uk.pcpartpicker.com/p/wTwpD3
What do think of it and do you think I should change anything?
Maximum budget is £450.
build looks okay for that budget, however, i would personaly grab a better mobo.
Like Asus M5A97 EVO R2.0 or the Msi 970 Gaming
+1, although if OP is not planning to upgrade to an 8 core, the ASRock Pro3 should be fine.
Rest of the build looks good.
