450-500$ budget gaming rig (first build)
hi guys,
im going to be building a computer soon, but i dont know what parts i should get,
im on a budget of 450-500 dollars and i might do a little gaming
if you guys could help me that would be awesome!
thanks
Do you need a complete setup or just the tower?
If you just need the PC this should do good
http://pcpartpicker.com/p/NfLA
For $100 more you can get a lot more power
http://pcpartpicker.com/user/xlxm/saved/1p1F
Or this is closer to your budget
http://pcpartpicker.com/user/xlxm/saved/1p1H
http://pcpartpicker.com/p/NfZl
CPU: AMD Phenom II X4 965 Black 3.4GHz Quad-Core Processor ($92.99 @ NCIX US)
Motherboard: MSI 760GM-P34(FX) Micro ATX AM3+ Motherboard ($42.99 @ Newegg)
Memory: Kingston Blu 8GB (2 x 4GB) DDR3-1600 Memory ($56.02 @ Amazon)
Storage: Western Digital Caviar Blue 500GB 3.5" 7200RPM Internal Hard Drive ($39.99 @ Microcenter)
Video Card: Sapphire Radeon HD 7850 1GB Video Card ($169.99 @ Newegg)
Case: Fractal Design Core 1000 MicroATX Mini Tower Case ($37.99 @ Amazon)
Power Supply: Corsair Builder 500W 80 PLUS Certified ATX12V Power Supply ($39.99 @ Newegg)
Optical Drive: Lite-On iHAS124-04 DVD/CD Writer ($16.97 @ Outlet PC)
Total: $496.93
Plz stop recommending APUs!!! keep them in consoles!
Give this a look http://pcpartpicker.com/user/GhostMistSniper/saved/1p23
It is a 6 core cpu with a 7870
It can play any game a high settings with good fps, it is $40 over $500 but if you have a HD
don't get the HD in this build and you will be at $500.
I hope this is helped you.
guys i forgot to mention this
i live in canada
canada vershon
http://ca.pcpartpicker.com/p/NgMw
CPU: AMD Phenom II X4 965 Black 3.4GHz Quad-Core Processor ($99.99 @ Newegg Canada)
Motherboard: MSI 760GM-P34(FX) Micro ATX AM3+ Motherboard ($51.99 @ Newegg Canada)
Memory: Kingston HyperX 8GB (2 x 4GB) DDR3-1600 Memory ($53.99 @ Amazon Canada)
Storage: Western Digital Caviar Blue 500GB 3.5" 7200RPM Internal Hard Drive ($58.50 @ Vuugo)
Video Card: HIS Radeon HD 7850 1GB Video Card ($169.99 @ Memory Express)
Case: DIYPC DIY-6811BK (Black) MicroATX Mid Tower Case ($24.99 @ Newegg Canada)
Power Supply: Raidmax 500W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($49.99 @ Newegg Canada)
Optical Drive: Lite-On iHAS124-04 DVD/CD Writer ($17.99 @ Newegg Canada)
Total: $527.43
