Include a dvd drive and wifi adapter
http://pcpartpicker.com/p/1MyiZ
just get another one of those 4gb sticks of ram later and you have a great gaming system for cheap
any FX 6300 ones?
unless you have already purchased the 7850 and are looking for a $450 system to go with it I dont think you can get a fx 6300 for less then $500
http://pcpartpicker.com/p/1MyJl
if you want a fx 6300 it costs a bit more. I would recommend the build I put in the post before and put 8gb of ram on it and you will have a solid machine
