Im upgrading my gpu this christmas to a 770 from a 7870, I would like to give my 7870 to my brother since his current gpu is an nvidia 260... his cpu is an amd 965 BE and the PSU is a corsair 80+ gold powersupply. Would this be enough to hold the cpu and that gpu? I know it will be cutting it close at around 399 watts (i think) but I would like to get some opinions.
It should be fine due to the amd card is would be using a little bit less wattage but it is cutting close
thank you this wont be a permanent thing I will buy him a new one sooner or later, I figured it would be ok since its a fairly high quality PSU and still has around 40 watts left or 80 it may be 480 watts I can't really remember.
actually comes out to 350 Watts roughly.. So should be ok without an upgrade wither way the PSU is almost 100 more than whats needed.
They recommend a 500 watt or greater. Never used a CX 430 with one of these setup. Could be OK. Make sure it can drive the right amperage before you attempt it.
When my buddy's PSU blew up he had a 500 watt sitting around. He tried to drive a GTX 580 even after I asked him not too. That yes technically there was enough watts but not amps. Fool did it anyway and killed his card.
The only 7870 I have found the amps is the Asus one. And I guess it needs 40 amps.
thanks alot ill look in to it now
where could I find how many amps the PSU can handle?
-Update-
I've read that the 430 has a 32A 12v rail, also keep in mind the 7870 is made by HIS, probably not as power hungry as that monster ASUS makes :P
It should be fine, as long as it's 80+ certified.
The 770 has GPU boost which could add approximately 50W to the load in addition to the stock values. It's kinda like an automatic overclock to give you an in-game performance boost. I honestly wouldn't feel 100% about using a CX430. Though, it could be enough with GPU boost turned off.
I know recommendations are often an over estimate. I don't think you would need a full 500W unit. It is better to be safe than sorry, and you can buy them quite cheap. If you can afford a 770, it shouldn't be too much trouble.
Its on the power chart sticker on the PSU. There is a column for amps and one for 12 volt.
