400$ Rig *updated*
So I plan to spend 400$ on a rig, its not gaming rig well... Since in my country called Croatia there isnt much hardware diversity I tried to build a decent gaming rig and there were limitations that made me sick. This aint cheap like in America, America, America... -_-"
Shell: SPIRE Maverick 6009 (plus some vent) - 39$
Power Supply: MS Industrial Platinum 400w (got)
Motherboard: ASRock N68-VS3 FX (AM3/AM3+) 55.50$
CPU: AMD Athlon II X2 270 3.4Ghz AM3 75-76$
RAM: Kingston 2 x 2Gb DD3 1600mhz 34.2$
Hard Disk: Western Digital Scorpio Black WD5000BPKT 2.5 SATA2 500GB 105-106$
GPU Candidates newegg is for info, price in my post is from a local shop called HG Spot:
ASUS ATI Radeon EAH6450 SILENT/DI/1GD3(LP) 1GB PCI-E 54.5$ http://www.newegg.com/Product/Product.aspx?Item=N82E16814121439
ASUS nVidia GeForce GT610-SL-1GD3-L 1Gb PCI-e + Torchlight 64.5$ http://www.newegg.com/Product/Product.aspx?Item=N82E16814125428
GIGABYTE nVidia GeForce N610 1Gb PCI-E 43.3$ http://www.newegg.com/Product/Product.aspx?Item=N82E16814121641
GIGABYTE nVidia GeForce N210 1Gb PCI-E 49.4/5$  http://www.newegg.com/Product/Product.aspx?Item=N82E16814125392
SAPPHIRE Radeon 6570 1Gb DDR3 PCI-E 2.1 x16 HDCP Ready Video Card 85.1$ http://www.newegg.com/Product/Product.aspx?Item=N82E16814102934
MSI nVidia GeForce N620 2Gb PCI-E DDR3 84.8$ - No newegg
I cant decide what GPU to pick so I ask you guys...
In future I will upgrade my CPU to AMD FX 8320 and it costs about 260$ compared to 200 in US.
scorpios are for laptops. get an a10 or even a8 apu if you can, theyd be better than a 610 etc. then you could also spend more all around for some extra higher quality stuff. you'll need like 8 or 6g of at least 1600mhz ram, 1866 is cool too, but pricy probably. apus <3 fast ram
I know, since hardware in my country costs alot and there is only like 1 or 2 maybe 3 motherboards that are FM2 and they are not the cheap ones... So it sucks. I cant go "best cheap ass gaming rig"... xD :/
