will this be a alright pc its gonna be my first build and im eventually planing on getting a radeon hd 9850 or a 9950
pcpartpicker.com/p/tvCW
if you think you can build a better pc for $400 link it please also will this pc be able to playdayz and stream nicely
Nice build. All I'll say is get thi Xigmatek Asgard Pro case instead. It has USB 3.0 and is still cheaper.
i just like the side panel so im prob gonna stay with the 430
Okay. Only suggesting for the 3.0 but if you aren't bothered :D
http://pcpartpicker.com/p/pq8v This one has a CPU cooler in it so you can overclock
