$400 gaming pc build! Need help finding a good mobo with the phenom cpu
I suggest this build here: http://pcpartpicker.com/p/nXFg
Also, use PC Part Picker for your lists. Makes it look much neater.
You may have gone a few $ outside of his price range. Just maybe.
Did I? Crap. Okay, okay. What if we take out one of the monitors and swap the 32GB to 16GB? Would that put it in the range?
