400 for a laptop
looking for a laptop. my price range is 400$ the laptop is for everyday use.
Any gaming?
Performance or Battery life?
US?
some not a lot of gaming
good performance
decent battery life
us as in united states yes
Probably the best option
i5 + 940M + 1080p screen
Iffy build quality, probably average battery life
http://www.newegg.com/Product/Product.aspx?Item=N82E16834315131
APUs aren't too bad a choice CPU/GPU wise, but it's hard to find a reasonably priced AMD laptop with a decent display, you'd have to live with a 768p TN display
APU option, A10 7300 + 240m thinkpad
http://www.newegg.com/Product/Product.aspx?Item=9SIA24G2NU4300
Literally as good as it's gonna get at that price range.
do you think its going to be cheaper on cyber Monday?
No clue, but there's no black friday deal for it, so I doubt there would be one for cyber monday
Highly doubt it, you'll be lucky if it isn't sold out by then. It's typically 500 every time i see it.
its is on sale it was 599 but now its 429
and thanks for helping me out
I think that's near it's normal price, but ya, just read the reviews, kinda gotta make sacrifices to get performance
Whatever laptop you get budget for an SSD swap out as the HDDs in basic laptops are abysmal!
I refuse to service any HDD based laptops now as I value my time too much :)
Unless you were willing to pay for a 480gb SSD it's probably not worth swapping out the hard drive
so how much better would i get if the budget was 500 $
I can't imagine finding much better than that as is, maybe get an SSD in the system, of course do you really need a laptop?
