$400 Build
I need a $400(max) build.I want something with high upgradability as well.Also,I want it to play games at Mid-ish settings at 720p,thanks.
Logan just posted a new vid on this on youtube. http://www.youtube.com/watch?v=D-4XFpMZgnQ
Here you go!
[url=http://pcpartpicker.com/p/RRc1]PCPartPicker part list[/url] / [url=http://pcpartpicker.com/p/RRc1/by_merchant/]Price breakdown by merchant[/url] / [url=http://pcpartpicker.com/p/RRc1/benchmarks/]Benchmarks[/url]
[b]CPU:[/b] [url=http://pcpartpicker.com/part/amd-cpu-adx640wfgmbox]AMD Athlon II X4 640 3.0GHz Quad-Core Processor[/url] ($64.99 @ Newegg)
[b]Motherboard:[/b] [url=http://pcpartpicker.com/part/asus-motherboard-m5a97ler20]Asus M5A97 LE R2.0 ATX AM3+ Motherboard[/url] ($79.99 @ Newegg)
[b]Memory:[/b] [url=http://pcpartpicker.com/part/gskill-memory-f312800cl9d4gbxl]G.Skill Ripjaws X Series 4GB (2 x 2GB) DDR3-1600 Memory[/url] ($36.99 @ Newegg)
[b]Storage:[/b] [url=http://pcpartpicker.com/part/toshiba-internal-hard-drive-dt01aca050]Toshiba 500GB 3.5" 7200RPM Internal Hard Drive[/url] ($54.99 @ Newegg)
[b]Video Card:[/b] [url=http://pcpartpicker.com/part/his-video-card-h777f1g2m]HIS Radeon HD 7770 1GB Video Card[/url] ($89.00 @ Newegg)
[b]Case:[/b] [url=http://pcpartpicker.com/part/nzxt-case-gama001bk]NZXT Gamma Classic (Black) ATX Mid Tower Case[/url] ($29.99 @ Newegg)
[b]Power Supply:[/b] [url=http://pcpartpicker.com/part/corsair-power-supply-cx430]Corsair Builder 430W 80 PLUS Bronze Certified ATX12V Power Supply[/url] ($34.99 @ Newegg)
[b]Optical Drive:[/b] [url=http://pcpartpicker.com/part/lg-optical-drive-gh24ns95]LG GH24NS95 DVD/CD Writer[/url] ($15.30 @ Newegg)
[b]Total:[/b] $406.24
[i](Prices include shipping, taxes, and discounts when available.)[/i]
[i](Generated by PCPartPicker 2013-04-20 05:31 EDT-0400)[/i]
* CPU good for this budget range and is QUAD core!
* Mobo will allow up to FX CPU's if you desire to upgrade to them later.
* RAM set is Dual Channel and runs at stock voltage of 1.5v, CAS 9 timings, and 1600 mHz speed.
* GPU is the best your going to get right now at this price point.
* Case is decent for the $.
* PSU is plenty for this build and can handle up to AMD 7850 or nVidia GTX 660 GPU's.
