£400 build UK :)!
Please find parts on UK website because parts in the UK are a lot more expensive than in America :(( !
I have been researching for ages but still not sure on what components to get, been thinking on getting a phenom II x4 965 BE but I really need some help!
Thanks in advance :) !
I know this is a bit over budget, and you might want to build it yourself, but ive got my new pc from this site with a similar build and its an i5 build for 415 which you wouldent be able to do building yourself. It claims to have a 3week wait but if you google for a 'dinopc discount code' you will get a 1week discount so it will be done in 7 days.  I recomend this because its easily upgradeable, stress tested, and more stuff like that and their is also a part picker on thier. http://www.dinopc.com/shop/pc/-b-NEW-b-Fabro-i5-3470-93p1572.htm
Thanks for the link, I think I might build it myself to save some money and also just for fun! Also do you know how much of a proformance boost I would get if I put a hd 7770 in the build later on?
i thought in the same way of building it to save money, but in the uk it kinda dosent work since parts are more expencive, i was in the same situation as you about 2weeks ago and i had done 2 months of research into building vs buying and you lose a bit more on the the building because its so many parts, and stuff like case, cpu cooler, psu, gfx cards are going to cost a bunch in posting...also buying pre built you dont get any glitches,  and possible problems like a home build. You also get a really good deal on warrenty so you get a good year on free part replacements :). Also i must say on that biuld, you can click customis. And take/add any parts you need or dont so if you have an OS already you can take it off to subtract £59. And about the gfx card, do you mean alongside the 560? if you do im not sure if that mobo has the capability but if so it will pretty much boost your fps in games by alot... -matt
Thanks a lot Matt, I really hate how parts are so expensive in the UK compared to America! I think I will look into it a bit more but pre-built sounds like the way to go! I can't wait to move to PC from shitty Xbox :L !
Haha yeah same man, i get my pc that i ordered on friday :) its the mass effect one on dinopc but with a few customisations, (specs are on my profile :p) and ill let you know how it runs games if you want a comparison:) you can always drop me a message if you need anything and ill try my best to help, best of luck with finding something that you will be happy with! -matt
Yeah some game benchmarks would be great thanks!! You've really helped me out man and thanks I might do :L !
Alrighty :) ill let you know asap about different benchmarks, any games in particular that you wanna play on this new pc?
Not really haha, maybe some mmo's, maybe skyrim, torclight 2, battlefield 3 (if possible) but I don't really mind!!
