So I built my friend the $400 APU build from a while back and we misread the temps so I popped in an EVO 212 I had lying around and it never fit the case so we had to keep the side panel off until we upgraded the case, well before we could do that the case was run over by a car, so now we figure if the parts still work what better time than now to find a bigger case and mobo so that the evo 212 doesn't block one of the ram slots on can someone help us out
...........What?
well...basically he went to put it in the trunk to drive over to my house and realized he left his keys inside went back to get them setting the comp behind the car...was distracted for a bit b4 proceeding to hop in and reverse.He then realized he just smashed the hell out of it.
So, what makes you think any of it is salvageable. I mean, if it was run over, at least the motherboard must have been wrecked.
well he did say new motherboard and new case...
These are what I like at a couple different price ranges.
The small form factor + affordable build: http://pcpartpicker.com/p/17Dz1
The small form factor Awesome build: http://pcpartpicker.com/p/1Ipj7
Full ATX affordable option: http://pcpartpicker.com/p/1IplC
Full ATX awesome build (but not crazy expensive): http://pcpartpicker.com/p/1Ipql
Of course you can pick and choose between different parts.. These are the ones I would get though.
Not enough info tbh.. If the PC got "ran over" I would imagine it got crushed to hell and nothing in there may be functional. I wouldn't mind seeing a picture of that.. Also going by your posts I'm not sure if you're saying that the PC got damaged or just the bare case. Either way what I would do in that situation is deduce what is functioning and what is not before you start throwing money around. Just my 2ยข
Check the parts, see what still works, then post again afterwards and we can go from there. ;)
Everything looks ok once I took it out of the case im not sure yet what works and what doesn't nothing looks bent 412
