What do you guys think of this build?
its nice and well bablanced. the only thing i would do is trade the 2gb of ram for 8gb.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148544
its only another $12 then the ram you are getting and it will totally worth it, unless you only play old games. newer games like bf3 takes a good 3 GB on big 64 player maps then add the 1.2 GB windows takes up and theres 4.2GB of ram being used. it's a little more future proof as well.
