4 way sli on Titan vs. 3 way sli on gtx 780 ti
I think 780 ti cant do 4 way sli... btw if you know the best 4 way sli setup let me know
why on earth would you need either? a monitor doesn't exist that could process the fps either would generate
what if I want to hook up 3 4K monitors to it
I'm assuming this is a hypothetical question... the 780ti is more powerful, but the limitation of vram might get in the way of a triple SLI system... so in theory, you might actually be able to use the 6GB vram of the titan with a 4x setup, and it would likely outperform the 3x 780ti...
but in actuality... that sounds like the biggest waste of $5500 I've ever heard of...
If I recall correctly, 4 way SLI with titans is not always better then 3 way and in some cases may reduce your frames. It is definitely something to look into.
Yup, he would need a lot of bandwidth to run anything more than 2 way.
motherboard woud be Evga x58
totaly waste, only socket 2011 ivybridge -E is capable, of doing a Quad gpu setup, on reasonable speeds. because ivy-e contains 40 pci-e 3.0 lanes. so you will be able to run a quad setup at X8 gen3, that is equaly to 16X gen2
Also i think  4 Radeon 290X non reference with 512 Bit bus, will do better then the titans.
So if i take 4 290X GPU's and i7 what motherboard shoud i get
This is the best way to do this: http://pcpartpicker.com/p/2AbEo you should probably also spend about $1500 at least in a custom water cooler loop to keep the whole thing from melting.
GTX780 ti is basicly the fastest single gpu on the market today, for gaming. but you also pay the price for it. still cheaper then a titan.
a GTX780Ti is faster then a 290X but if you run a 290X in uber mode, its not that far behind.
http://pcpartpicker.com/p/2AAat So how can i make this better
well if you gonne watercool the gpu´s then okay, but if not i would not recommend those cards, because the reference coolers are not realy silent. thats why i said, aftermarkert 290X. or just grab 3 or 4 GTX780 ti´s, if you realy want the best gaming performance.
Don't spend this level of money on a computer if you do not understand what you're purchasing. You could be wasting a lot of money, purchasing stuff that you simply do not need. Take some time to research and allocate budgets to your actual needs.
I know that there is litle diference from 2 way sli and 4 way sli on this card's in raw FPS but I am building the most overkill PC i can
I dont mind that they are not that silent, i dont keep my PC next to me but i tought gtx 780 ti does not suport 4 way sli
Overkill is relative. If you wanted to run three 1440p monitors in surround/eyefinity, I would totally advocate what you are doing. However, if you want to run a single 1080p monitor, a single 290 or 780 will pretty much max out all games.
Don't spend money if you do not need too. Performance requirements are relative.
