for the OP from here
https://linustechtips.com/main/topic/610476-10-oss-on-1-pc/#comment-7895322
10 machines from 1 while neat, seems like it would be a massive pain, so I came up with this
Is there a better way to do it? 4 machines per 1 physical seems a lot more reasonable and easy to do with something like this where the GPU has 4 mini display port outputs and is low power
Is it best just to run a host OS off a USB stick and do 4 virtual machines from there? Or just have 1 main machine and 3 virtual PCs?
"The slightly less pain in the ass way to do it would probably be AM3+
based, just downclock the CPU to like 2ghz for lower power consumption
and a machine like this would give you 4 systems in one, the workstation card is low power and has 4 mini display port outs
just give every machine 2 cores, 8gbs of RAM and an SSD, probably
running live GNU/Linux of some kind from a USB so you don't need a host
OS, or just install an OS onto one of the drives and have that be one
machine, dunno if it has enough USB ports
Also I don't know if there's going to be a bandwidth issue having 4 PCs share one hardware connection
PCPartPicker part list: http://pcpartpicker.com/list/YGzpgL
Price breakdown by merchant: http://pcpartpicker.com/list/YGzpgL/by_merchant/
CPU: AMD FX-8300 3.3GHz 8-Core Processor ($118.88 @ OutletPC)
Motherboard: ASRock 970A-G/3.1 ATX AM3+/AM3 Motherboard ($79.99 @ SuperBiiz)
Memory: Mushkin Stealth 32GB (4 x 8GB) DDR3-1600 Memory ($109.89 @ OutletPC)
Storage: A-Data Premier Pro SP600 128GB 2.5" Solid State Drive ($39.99 @ Amazon)
Video Card: AMD FirePro W4100 2GB Video Card ($169.99 @ B&H)
Case: Fractal Design Define S ATX Mid Tower Case ($69.99 @ Newegg)
Power Supply: EVGA SuperNOVA P2 650W 80+ Platinum Certified Fully-Modular ATX Power Supply ($98.68 @ Amazon)
Total: $807.38
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2016-06-13 00:51 EDT-0400
Something I'd like to play with should I ever have the spare cash is
buying one of these USB docks and passing it through to a virtual
machine
http://plugable.com/products/ud-160-a
I think you'd need a PCi-e USB adapter to passthrough, and I'm not sure how it would work with a virtual machine
