So my kingwin adapter had the two black wires get pulled out. I dont know what order to put them back in. Heres a picture of the dilemma https://drive.google.com/open?id=0B-z_BC7woKGPZ01Md0dUU0gwVWs Does it matter what order? Here's a different angle. https://drive.google.com/open?id=0B-z_BC7woKGPcWlJMlpPMVpja29zTHhJVkE3RTQyUUs5YUZJ
it's 2 dollars on amazon. why risk your expensive equipment when you can buy a new one for less then a cup of coffee?
I know I should, but my dad is insisting on spending no more money. I'll just buy it again from microcenter. I cant really wait more than a day to get it.
Mirror the molex connector you had it connected to. Bend the little tabs back out a bit and push them back in should takes 20 secs. They're just ground/common and are usually the middle two. Order shouldn't matter.
Well google has you covered - just do it like in that picture, thats 99% even the same generic molex to 4 pin CPU adapter:
http://images17.newegg.com/is/image/newegg/12-423-185-TS?$S640W$
It's these little "wingithingy" that stand out, that you must bend out carefully so the pins will stay in the plastic casing:
