Okay I just updated ny PSU to a corsair CX600, and my motherboard has a slot for a 4 pin connetor, no not a molex a 4 pin, it looks identical to a 6 pin but with only 4 pins, please help where can I get some kind of molex-4pin adapter?
you have it
Features
- Connectors
- 1 x Main connector (20+4Pin)
1 x 4+4 Pin ATX 12V
1 x EPS 12V
2 x PCI-E
6 x SATA
4 x Peripheral
1 x Floppy
there is a 4+4 pin on the PSU, use the one that fits
I don't have it dude, it say the 6 pin is this
ooo
ooo
The 4 pin I need is this
00
00
not the molex
0000
Don't ALL motherboards have a 4 or 8 pin? its for cpu power..
Plug the one that has 8 pins into it. half of the pins will fit into your 4 pin.
Plug in the 8 pin that doesn't say pci-e you silly.
This is the 4 pin I need it looks like this
no, that is not what you need, you need to look through what you have and post pictures if you cant find it
you don't put molex on a motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139048&Tpk=cx%20600m
all pictures popup, 2nd row 3rd column, see that 8 pin conector, it breaks into 2 4 pin conectors
lol, it's there dude, typical user.
Sorry excuse me I didn't know it splits
