hi everyone,
i got 4 monitors, a 1080p 144hz monitor (dvi), 2x 1024x800 (vga) and one 1080p tv (hdmi). i got a r9 290 with 2x dvi, display port and hdmi. is it possible to use all my monitors and run my 1080p monitor at 144hz? and ifso, how to set it up.
As long as you use the right connection to the monitor, which will be stated in the instructions for it then I cant see why it would not run at 144hz. Use the HDMI port for the TV and then it would just be a matter of buying adaptors for your remaining two ports to connect it to the VGA monitors.You will most likely need to set your 144hz monitor as you primary display to get the refresh rate ingame.
i also got an other gpu which i can use. i think it's a nvidia but that doesn't matter i believe because my r9 290 is my 1st gpu. can i use the vga on the second gpu, the vga on my igpu (HD4600) and the hdmi and dvi on my r9 290?
From what I have heard it is sometimes possible but not really recommended as there is the potential for driver conflicts, especially if they belong to two different brands.
oh oke. i found a dvi to vga adaptor :) so i'm good. 1 tv. 1 1080p monitor and 1 1024x800 monitor. i can't use the second 1024x800 monitor but that's ok. i can use that for a different pc.
Sounds good :) Glad I could help!
