Does anyone know of any issues that I could face with 3x MSI Radeon 7990 cards stacked one on top of the other in regards to heat?
These things are going to be running at close to 100% with perhaps a little bit of overclocking, 24/7 for a little while (no prizes for guessing what I'm using them for then!).
I have a nice airy case (CM Storm Stryker).
Will I need to use risers to ensure they're stable?
I do intend to watercool these later, but for now I just need to plug and play as quickly as I can.
Honestly, get a specialized machine instead of spending 2k on gpus that won't mine nearly as well as a dedicated machine. Maybe keep enough to get one 7990, or buy a 290x and buy one later, after price cuts, with you money you kept for that one 7990.
Anyway, there are better, more money efficient ways to mine than buying GPUs.
You're confused with Bitcoin mining. Yes, there are ASICs for Bitcoins, but this doesn't apply to scrypt based currencies where GPUs are still the best option.
