3ds, y u no work?
Hey forum, I have a black Nintendo 3DS and it no work. It hasn't worked for a while but I haven't posted anything.
Basically, what happened was that I hasn't played my 3DS for a month, and then a month later when I wanted too, I saw 3 crack like things on the top of my 3ds (when its closed), and when I clicked the power button, the power indicator would be blue but nothing would happen.
At this point, I start to worry that someone broke my 3ds because before a month ago there was no 3 cracks on the top of the 3ds.
Now (many months later), I attempt to fix it by removing the battery, leaving the battery out for a week, let the battery die while the 3ds is on, and none of that worked. One time, only one time, my 3ds said something like "your system has experienced a problem and is shutting down" and it said something like that and more, but before I could finish reading it turned off. I also tried plugging it into my computer but nothing happened.
I'm basically desperate now because I miss my poor 3ds (I'm 15, youre never too old for Nintendo) and I want to play it really badly.
Has this happened to anyone or similar? If so, what did you do to fix it? If not, what do you think I should do to try fixing it other than sending it somewhere to get it fixed by someone else.
Thank you to everyone and anyone who could help me get this fixed.
Also, not sure if this is the right forum place, so if its not the right place, can someone tell me where to put it, or do it for me? Thank you and thank you if you can help me.
Pictures: http://m.imgur.com/ukLJTN1,dRRFt1V
sounds like it's broken, try searching online to see if there are any 3ds repair people out there. you might have to send it out to get fixed and im sure it will cost a pretty penny.
yeah.. sadly those Nintendoes are quite flimsy, they break really easily, Listening to a Rooster Teeth pod cast you learn about how easily some have broken, it would pay to take it to a repair tech to diagnose , but usually you would just replace instead of repair...
You can call Nintendo, they normally fix things for free, even if you have no warranty, most of the customer service people are ungodly nice. You can repair it yourself though or call someone to repair it for a price
OK, well thanks for the responses. I shall call them soon :3
